I was playing with my fan controller program today, because i will be changing case fans soon with nexus 120mm and 80mm fans. and i was also looking into possible aftermarket cpu fans that are about the same height as a stock AMD 64 HSF. Is the Zalman cnps7000-cu a good choice in terms of default sizing? i need one that improves airflow and noise, but not sacrificing the small scale size of the default. Any suggestions? or is the zalman the way to go?
Back to the original question of post however, when i was playing with ITE's SmartGuardian fan controller/temp monitor, i was trying to get a feel as to what my comp will sound like with all the new fans in it. I turned off all the case fans, cpu fan, and northbridge fan; trying to emulate a silent/near silent setup. I noticed that my cpu and chipset temps slowly rose, which is normal as the fans are off. but then i noticed that my PWM IC temps began to drop! My temps with my stock case fans and stock HSF were already sufficient since my computer sits on my desk next to a window with very cold ambient temps of ~ 5-6C. So perhaps it was because with all the fans ON, there was heat generated in the PWM? and when the fans were off, that heat was not generated anymore? I was looking for someone with better understanding of this to give some input. Thanks
