Turning an LCD monitor into a TV
evolvedbullet
543
I want to make my LCD monitor into a TV screen so that I can play my games on it (PS2 games and other games and what not). What will I need to download, buy, install, and get to have this happen? Links, advice, explanations, anything is considered helpful. Thanks ;). I really appreciate this.
Tiamat
14,068
For Xbox360 - VGA cable.
For PS2 - VGA box from hong kong. (or upgrade your LCD to one that has component inputs)
The easiest way is obviously to obtain an LCD screen (like the dell ones) that have all the connectivity you would need.
Another option is something like the ATI TV Wonder card. However, there are slight sync issues, enough to make parrying in street fighter 3 (for example) impossible.
coldmeat
9,231
139
You can't buy component -> vga adapters?
Tiamat
14,068
They cost 100$. They aren't wire to wire adapters. You have to buy a transcoder. Viewsonic makes some for example.
SlickSnake
5,235
You need about 1 pound of magic fairy dust. Just sprinkle it over the connectors on the monitor and POOF it's an HDTV.
Soundmanred
10,780
Originally posted by: SlickSnake
You need about 1 pound of magic fairy dust. Just sprinkle is over the connectors on the monitor and POOF it's an HDTV.
I searched everywhere on the Monster Cable site, and couldn't find this item.
Link?
