Turning a regular GeForce into a Quadro
PrayForDeath
3,478
I read somewhere in these forums about an FX 5800 U turned into an FX 2000 using some modded drivers.
And I also heard that all the GeForce cards (1-6) could be turned into Quadros using modded drivers too, anyone knows where can I find these drivers? Or how do I mod my own drivers?
And are the Radeons able to be softmodded into FireGLs? Because both series have the same architecture (I think)
SickBeast
14,377
19
Guru3D
FORUMS
I only have experience with the 9700-->FireGL mod. I actually used a special hacked driver set that I can send you if you pray for drivers. :p
AFAIK all you need is the newest RivaTuner. It can somehow "hack" the Quaddro and FireGL drivers so that they will work on your card. Good luck. :beer:
