Zebo
- Jul 29, 2001
- 39,398
- 19
- 81
Originally posted by: Zebo
Originally posted by: MegaWorks
Who has a VIVO for less than 300 bucks?
LOL
Originally posted by: pelikan
Thanks for this thread.
I found a used Sapphire X800 Pro VIVO retail for $350., locally. I'm now running at XT PE speeds with 16 pipes!
I ended up using W1zzard's method instead. If you use his modified flashrom you can go back to 12 pipes if necessary. But the Gigabyte flash tool will leave you stuck with 16 pipes, even if they don't all work. Also, W1zzard's method only requires flashing once. I flashed directly to the latest X800 XT PE bios, after backing up the default bios, and it worked great.
Edit: I got 5801 in 3DMark 2005, with highest quality settings. Temps are 59C after one hour of Doom 3.
Originally posted by: Bleh
So I take it that the x800pro thats made and distributed by ati does not have vivo or the 1.6ns memory?
Luck of the draw, really. My BBA x800 Pro had VIVO and 1.6ns RAM, thus I was able to unlock to 16 pipes, although running at 515/500 only (might change when I get an ATI Silencer... one day).
I'm sure that the ATI Silencer will help a lot.
Originally posted by: limpo
Does anyone know if this will work with a Sapphire X800pro VIVO Toxic? Do they have their pipelines cut? Will the flash get rid of any of the Toxics software features?
WORKS ALLMOST GREAT x800 toxic256 @ x800xt pe 16pipes (520/560)
but i the screen sometimes freez up when i am running 3dmark03. (maybe driver fault) score12436
Before i flashed the card i run the atitool 10min @ 525/565 whit out failure.. score 10900
I will come back later whit updates
sorry for the bad lang...
thx for a kickass forum....
Thing is, I'm not sure if $40 CDN can justify the performance gains, assuming I would be able to hit 520/560, or beyond (at this rate, highly doubt the "beyond" part). On the other hand though, I take it my x800 will have a longer life because of it (logically speaking)? Not only that, it looks high-tech too.
Kinda short on money right now, so it's definitely not in the picture. Would be nice if prices went down by a reasonable amount by the time I do, if ever, decide to get one.
Originally posted by: Rizzoa13
Hey guys im thinking about getting a sapphire x800 pro and flashing it to the xt suing your method i just want to know if the flashed "xt" will run with my 4x AGP motherboard. The card comes compatible to my 4x card i jsut wanted to know if flashing it to the XT and changing it's bios will make it incompatible with my motherboard. Thanks in advance
Originally posted by: KayGee
hey guys, i have an ati brand radeon x800 pro which seems to have all the features of a VIVO. it's got the samsung 1.6 ns ram, rage theatre chip and the yellow connector next to the power connector. well, i tried modding it following the instructions exactly as they were listed in the first post and used the ati x800 xt bios instead of the gigabyte. everything went ok and i was able to install new drivers, but when i open atitool, it says 520/560, BUT ONLY 12 PIPELINES. i thought it was a "proper" VIVO card which should have taken to the mod. SOMEBODY PLEASE HELP!! ANY SUGGESTIONS ANYBODY!! THANKS.
