Originally posted by: darkwaffle
I'm curious, has anyone tried this with the HIS Excalibur IceQ II version of the X800 Pro? I've been looking for one of the HIS Excalibur IceQ II x800 XTs, but I haven't any luck hardly, and I figured this a viable alternative. Very few places seem to carry HIS cards, and even fewer (if any) have the hi-end ones in-stock.
I was able to find this image in a review, and it appears that they have the "yellow connector", and I'm quite sure (from many pictures of the cards) that it has the VIVO port. Here is the yellow connector taken from the review here. So I'd suspect it would support the softmod, but I'd love a second opinion.
Just a thought also, due to it's higher-quality cooling unit, would this perhaps increase stability at regular x800 XT PE speeds? And perhaps allow one to go even further? Thanks for your input.
Newegg link for anyone interested.
Great!!!
HIS Excalibur X800PRo with vivo now an XT Platinum.
with 16pipes.
using the default 520 core and 560 mem. ATI Tool had no errors @576 MHz mem
Now have 2x unknown devices related to the XT platinum primary and secondary, not sure what those are about yet. Installed the New Catalyst drivers.
Works Great. thanks
Originally posted by: DoobieOnline
Anything over 560 mem gave me some artifacts with ATI Tool so I located an X800XT (500/500) bios and flashed again. With ATI Tool, the core got all the way up to 583 before my rig locked up.I decided to run 550/550 and after playing games and running benchmarks all night it appears to be stable. I scored 6008 in 3DMark05 at 550/550 using the latest Omega's. That's 800+ marks better than my BFG 6800 Ultra OC scored in this same rig! :Q I was kind of bummed that the mem wasn't stable at 560+, but the core more than makes up for it. I may bump up the core a few MHz, but I doubt it since 550/550 is running great and I don't want to push it too hard.
Thanks again for all the helpful info guys!
doobie
I run it at 500/500 except for gaming.
Originally posted by: BuRnInICE
This sounds really interesting
I've got an Asus AX800Pro Vivo 1.6ns that I want to flash. I've gone to techpowerup and seen that they have a bios there for the ASUS AX800XT. If I do this mod can I use that bios instead of either the giga-byte one or ati retail mentioned in the "how to"?
Originally posted by: onoffon
Excellent Info! Know of anyone trying this with a Sapphire Toxic x800 Pro VIVO? New to moding and wondered if this would provide an adequate solution to heat concerns?
Originally posted by: MegaWorks
It's official, use only the Gigabyte bios to update your X800 Pro VIVO to X800 XT PE.
BuRnInICE, it's good know that the Gigabyte bios worked with your card. This really shows that this mod works 100% with any X800 pro VIVO.
The card looks identical to my Powercolor. With good ventilation the heatsink should be adequate as it is all copper. Kinda of pricey though at $200 more than I paid
Just did a 3dmark 2005 comparison.
Stock standard Asus AX800 256mb VIVO 1.6ns Samsung - 3790 marks
Modded to ATI X800XT PE 256mb with 16 pipelines and @ 500/500mhz - 5389 marks
Almost 1600 marks increase.
Temps during the benchmark was from 43 degrees idle to 51 degrees load
My card has the stock standard Asus Cooler on it with 4 ramsinks on opposite side (One on each memory chip) I've ordered an Arctic Cooler ATI 4 to help keep it even cooler.
