Originally posted by: Uhtrinity
I used the directions here:
http://paddy007uk.freeservers....VO%20FLASH%20GUIDE.htm
With the exception of booting up with a win98 cd, and flashing straight from the hard drive. If something does go wrong you can reflash, but connect your monitor through a PCI video card.
Originally posted by: Narnos
Hello All,
I am a new member, however have been reading the forums for a while now. When I was doing some upgrading I found this little thread and it sold me on the x800pro VIVO. Please keep in mind that the suppliers in Australia don't even stock a x800xt and ordering one is just out of the question especially as here the price difference was around $300aussie.
Finding Nvidia cards is almost as hard, however the price again is far too expensive. So I took the plunge and bought an HIS x800 pro VIVO with the ice berg II cooler (or whatever). The one that claims to reduce the temps by 11 degrees.
Anyways, being far too keen I flashed my card without even checking the RAM and I must say that all of your guys/gals are LEGENDS!!! I now have a fully functioning x800xtpe with 16 pipes running at 540/580 (1160). I do not require vmod at all and the card idels at about 38 and peaks under full load just over 50 degrees.
Thanks to all the lovely people at this amazing forum as now I am playing at the res and picture quality I though I would be a few years after getting my 3dfx card with permenant FSAA.
Keep up the good work...
Originally posted by: sbuckler
Beware, nothing is without risks, this guy modded his, it worked fine for a few weeks then died. Checkout the thread
http://www.hardforum.com/showthread.php?t=804930
Being as it's so hard to get X800XT's I can believe they're turning working ones into pro's just yet, it might be a simple as it wasn't quite stable at XT speeds, but there could be a more serious reason.
~ I think if I had a moddable pro I would leave it as a pro for the moment (other then bragging rights there's ~ nothing that really need an xt right now so it's hardly the end of the world) and let someone else take the ~ risks till I know its safe.
Understandable, but realize that is why most of us bought this specific card. Now, as far as performance, there are games that can take advantage of this card, Doom3 and Farcry I two that I have. Half Life 2 will be another once released. It is also nice knowing that you can max out settings on most other games.
After thinking about it I would suspect that he popped a memory chip, after all he was pushing above 1200Mhz ddr. Like i said earlier with water these GPU cores barely get near 40c which is slightly above 100F. I have also seen some scores on Future mark that showed cores clocked around 800 Mhz vaporcooled and over 600Mhz water cooled. Just starting to play around with voltmods on the X800, expect to push roughly 100 Mhz over stock PE speeds. Won't push memory over 1200Mhz though.
Example of super extreme: http://www.xtremeresources.com...showthread.php?t=32822
