Terzo
Friday my front driver's side turn signal was clicking fast. I've been told that's generally a sign of a bad bulb, and indeed when I looked the front signal was not working (all the other turn signals were working fine).
After some fun taking the casing out of the car (apparently the screw hole broke and it's zip-tied down) and taking out the socket I luckily discovered the bulb does work. Figuring that the connection must have been loose or something, I returned the socket to the housing and tried it one last time to make sure everything was peachy.
Except it didn't work again. What the hell?
Cliffs:
Turn signal works when socket is outside of housing, but does not work when inside housing. What is my problem? Car is 93 civic if it helps.
Cliffs:
