Greetings Gentlemen, wow those are much better responses than I've gotten over at mr2.com and mr2oc.com...I think I'll post more here.
But... I have to ask... why are you certain that the turbo needs rebuilding? Have you taken it off and inspected it? Or at least seen how much shaft play there is?
Answer is I don't which could indeed be a good thing. I am just planning ahead just in case of a worst case scenario. I discovered that leak when I was done working on the car this last weekend so I didn't have time to do any further research. Additionally, I think there is another leak coming from the "other side" of where the turbo is located so that is why I assumed the turbo.
Pop the intake off and wiggle the turbine shaft. When turbos leak it's typically going to be burning oil, not leaking through the compressor side. That looks like it may be oil from the crankcase vent (look at the hose running from the driver's side of the valve cover into the intake plumbing) building up in the intake. I'd take that off and see how much oil is in there.
Before I go on and on..what's your goal for the car, and how much do you want to spend on it?
Great question. I'll probably go more into detail when I post my first "build thread" much like yourself and Fuzzy did. My goal at this time is to fix the car such that it is not leaking. Currently, after I drive it, there are approximately 5 droplets of oil that form from different locations under the car. Some of the sources of these leaks may be the same but I am not sure.
Yeah good thing is that I don't think the car is burning oil (No blue smoke, no white smoke, no smoke)...but it is indeed leaking.
Right now I am try to minimize costs since I just got the car and have been spending quite a lot to get it running. Eventually I would like to upgrade to better parts that need replacing...everything from intercooler, radiator, intake, wires, plugs, etc. It's supposed to be an ongoing "fun" project.
The oil gathering at the intake side of the of the turbo could be coming from the PCV (positive crankcase ventilation) pipe, and not from the turbo itself. It is normal/common to have a little oil there. Lots of oil like that could be due to excessive blowby ... Gas blowing past the piston rings and into the crankcase. That gas gets recirculated from the top of the head thru a black pipe going to the side of that intake pipe you posted a photo of.
First thing you shpuld do is a compression test, or even better a leak down test. This will determine the health of you piston rings.
To Do List:
1) Yeah I have not wiggled the turbine shaft to yet to see how much play is in there. I'll do that when I can work on the car again probably this weekend.
2) I will also research what a compression test and leak down test consists of. I'm still a novice with this car diagnosing stuff.
3) While doing #1 I'll clean up the area that has oil and take a look at the PCV and see how much oil is around there.
So here is a video that I took when I first got the car home a week or so ago:
http://youtu.be/GEa_5JY7Bmg
Note that I originally thought that there was a coolant leak. And there indeed might still be but I have not noticed it since driving it around some more. In the video it will show "wetness" all around the edges of the oil pan and that is what I am guessing is the main cause of the oil problems. But the caveat to this is that at 2 "other" locations, it looks like there is leaking coming from above the pan. The first is the "bracket" that I mentioned in the video which could be near the turbo intake and the second is on the "left-hand" side of the video where that "funny lookin" pipe is.
So this weekend the goal is to: 4) Drop the oil pan, clean it up, and put it back together using Totota FIPG.
