Tuniq Tower Fan Question
jleves
I'm kind of trying to pimp my rig out, so I dropped an LED fan into my Tuniq hoping for a cool effect of the light coming out the fins, but with the other LED fan lights, it's not really noticeable. Hence my question:
Is the stock Tuniq fan better/worse than the fan I put in. I used a Thermaltake Thunderblade rated at 78cfm. I posted something earlier about this fan and people said it was good, but louder than claimed. At full speed, I can't hear it, so the noise is not a problem. I understand the Tuniq fan is 9 blade and the Thermaltake is 7 blade. So, should I put the stock Tuniq fan back in or am I good to go with the Thermaltake?
Easy enough answer - watch your temps. Put the system under a full load with one fan, then with the other. See if there's any difference. If there is a difference, is it an acceptable one to you?
