I used this program and now when I try to open a folder it opens as "Notebook" in OneNote.
EDIT*** Also, when I try to open the recycle bin, it creates a shortcut to it.
Last, when I try to open the C: drive, it opens Computer Management up.
I was pissed off and uninstalled TuneUp. I didn't see any "undo changes" thing in the 1 click maintenance anyway. I'm sure it was there somewhere, but it wasn't in my programs menu either.
Anyone have the registry values to fix these?
Even if you have one of them I'll take it.
TIA
EDIT*** I know that program screwed up my registry values, but I don't know the default values.
Messed up entries
My Computer:
HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Manage\Command
Value is: %windir%\system32\mmc.exe /s %windir%\system32\compmgmt.msc
The value is obviously wrong
I need your value please
I need the one to open the C: Drive as well, but cannot locate it for you guys
I cannot find the entry for the recycle bin either. When I click the recycle bin, it creates a shortcut to it. I search for "shortcut to recycle bin" since it replaced the Open entry, but had no luck
I appreciate any and all help, thank you.
EDIT*** So with all the smart remarks and the so-called geniuses here, I've came to the conclusion that this cannot be hard. I do thank the people that did help and this minor set-back will not stop me from helping anyone at all. I would love for anyone, to ask questions of any category and I will help as much as I can.
Thanks everyone.
TIA
Messed up entries
My Computer:
Thanks everyone.
