Tuner works in WMC, but not in other Software
wolf2009
1,000
I have the Avermedia M780 Combo PCI-E Tuner.
I have the Comcast Basic cable which is directly hooked to the card's input and no set top box in between
I can use the tuner in Windows Media Center in Vista x64 perfectly and watch the channels with good quality .
But I can't get the tuner to work in Aver Media center. The software does not scan for any channels on cable setting.
What other free soft can i try ?
Shawn
32,236
53
What's wrong with WMC? It's way better than Avermedia's software.
wolf2009
1,000
can i record in wmv or divx or other codecs ?
also the live tv takes up space on OS partition , i wanted to change that to a bigger partition .
Shawn
32,236
53
Did you contact their support? I found their software to be extremely buggy. There probably isn't much more you can do other than replace the card or use a different program. I think BeyondTV can do what you want.
