Tuner card trouble
madh83
149
I bought an avermedia m780 and was using it for 2 days. Suddenly, I stopped getting a feed. Now when I try to start avermediacenter it just crashes. I also tried to check it in GBpvr which was working before, but now it says failed to initialize BDA card when I try to update the EPG. However, under device manager there are no red flags and the device appears to be fine. I did try uninstalling and reinstalling it...so..did the tuner just die ?
robisbell
Banned
Oct 27, 2007
3,621
manufacturer and model of system:
manufacturer and model of motherboard:
make , model , and amount of ram:
manufacturer and model of video card:
manufacturer and model of HDD:
Amount of Free Space on HDD:
version of OS:
