Tundra engine code
lupi
I'm getting a 441 engine code, "EVAP emission control system purge fault"; any idea of what's wrong?
Originally posted by: andylawcc
could it be EGR? ? ?
EGR controls combustion emissions. Evaporative emissions are unburned hydrocarbons from the fuel before it is burned.
It is more than likely that the purge solenoid is not functioning correctly.
A broken hose could cause an idle problem, but a slight crack might not and still trip the code.
