Well. First of all I want to let you know that I did the wire trick MYSELF without soldering at all.. Just took som very fine strands of copper from my hifi speaker cables.. I managed to make it go around the two pins in a ring.. and I put on a tiny ammount of glue to keep it in place and then I put the cpu back in and to my surprise it actually worked!!! 1.675 V default!!! I'm soooo friggin proud of myself
However.. that didn't help my overclocking one bit. I can go up to 120 mhz fsb and everything i fine. But that is with the 3:3:1 divider.
If I go up to 4:4:1 I can't boot at all at any speed!.. what is wrong?
I have two mosel vitelic 128 meg dimms, rated at cas2 @ 133 mhz.
Did I miss something?.. I can't even make it boot at 101 mhz using 4:4:1 but 120 is fine at 3:3:1.
PLEASE HELP ME OUT!!
