TTL Flash with MF lenses
jtvang125
Would the flash work in TTL with a MF lens on a dumb adapter? I'm thinking no since no focal length and aperture info are being sent to the camera.
The way that TTL works in most cameras, I believe this should work. The focal length and aperture aren't taken into consideration in most TTL implementations. It simply measures how much light comes through the lens.
However, I could be wrong. Try it out and see how it goes!
I want to agree with slash that as long as you can meter through the lens (camera tell you underexposed vs overexposed), TTL flash should work, but I've never tried.
It depends on the type of camera and lens you have. I know with Nikon, you'll need to enter distance information and the focal length on the flash if it doesn't have a chip (AI). Chipped manual focus lenses will share this information.
With Canon cameras, ETTL sends out a pre-flash millliseconds before the actual flash. The light going Through The Lens (TTL) is measured, and an appropriate flash output is sent out based on the measurement. It doesn't care about the aperture, focal length, whether you have a polarizer on the lens, etc. All of those things will change the measured preflash so they don't have to be taken account of. I assume the Nikon is somewhat similar, though I don't know exactly how it works.
