- Mar 29, 2010
- 3,691
- 21
- 81
I think its just called finfet+ or something like that. I made correction thanks.Volta is TSMC 16FF
And they are going to drag it out. 2 years of Pascal, 2 years of Volta.
they are skipping 10nmAre they going to have 7nm working well enough for big(ish!) GPU's by 2019? Seems an ambitious target with 10nm to get through first.
10nm they presumably will have, but that might not be enough of a jump for them to bother with it, as per 20nm.
Who needs system RAM at this point. Just run everything off the GPU!!!! Haha.
Makes sense. Thanks!It'd be NV. Like they did with 20nm - these new designs are getting really expensive to do so it takes quite a big performance jump from the node to make them die shrink.
