C Corporate Thug Lifer Apr 17, 2003 37,622 0 76 May 22, 2003 #1 how is the thermal sensor supposed to be installed? should i just slip it it through one of the slits on my slk800?
T thraxes Golden Member Nov 4, 2000 1,974 0 0 May 22, 2003 #2 Are installing it on your CPU heatsink? then yes, but make sure that the sensor is as close to the heatsink base as possible for best performance.
