TT Crystal Orb and GeForce 4 Ti4200??
blakeatwork
4,113
Will this combo work better then stock... I'm assuming so, based on the cooling difference I say on my old Kyro II, but I wanted opinions...
Elcs
6,278
I dont think the Corb fits a GeForce4. I believe you'd need a specially built GeForce4 cooler.
boi
1,695
Yeah, it doesn't fit on the G4. Even if it did fit, it would probably perform the same/worse than the stock cooler. There is just not enough surface area on it to dissipate all of the heat that the G4 produces.
