Hi all!
Just finished building my new computer, relevant specs as follows.
AMD 4200+
Asus A8n-e
BFG GeForce 7800GTX
Tsunami Dream case with window
Now here's my problem. My processor is running a little warmer than expected, running between 34-38c at idle depending on whether it's the Ntune monitor(cooler) or the MB(Hotter) reporting the temps. I ran two instances of Prime95 last night for a few minutes and my temps went up to 46c under load before I shut them down(Ntune monitor).
I originally was getting temps in the 40's until I pulled the HS and reapplied the Artic Silver discovering the coverage on the core was a little spotty.
I've read in many places that the fans on the Tsunami case were loud. But on mine I can't hear them at all, they're very quiet. So I'm beginning to wonder if Airflow isn't why I'm getting temps higher than I thought I would.
I hooked up all of the fans, and the Front Intake and Rear Exhaust fans are hooked to the motherboard monitors. All of the fans are sharing the same chain of power connectors along with the DVDR drive. The other chain is dedicated to the 7800GTX. Seasonic 430w Dual Rail PS btw, don't know if it matters.
The Bios is reporting rotation speeds of ~2000 for the CPU, and ~1500-2XXX for the two case fans.
Cool & Quiet and Q-fan are disabled in Bios.
Anyone have any ideas? Does this all sound ok, or is something maybe not right with my setup?
I'm a little lost because I'm planning on venturing into my first OC with this processor, and haven't payed attention to this stuff before.
AMD 4200+
Asus A8n-e
BFG GeForce 7800GTX
