Info TSMC, Samsung and IFS's Quarterly Financial Reports
Markfw
May 16, 2002
27,410
16,263
Here is the source, yeah AMD is not listed. Anyhow the information is for this year, AMD should have more tape out for 3nm which contribute more. N4P is relatively cheaper, maybe that's why...
Maybe its lost in the chinese to english translation, as its not there either. In fact look here: They are 3rd.
(link https://exploresemis.substack.com/p/tsmcs-top-10203040-customers-who)
Tigerick
942
858
Markfw
May 16, 2002
27,410
16,263
Yeah, I have reread the article, it seems to list top 6 OEMs for 3nm revenue, then it is making sense. Anyhow it is unofficial list, do you have list for 2023?
PS: I have removed top 6 list due to different context.
Google listed that one, I did not look down the list further.
Tigerick
942
858
202320242025202620272028
IFSIntel 3Intel 18A
Density143195
SamsungSF3ESF3SF2SF2P1.4 nm
Density159178187198243
Perf / Power6.567.799.6210.55
TSMCN3BN3EN2A16A14
Density283273313349392
Perf / Power9.310.2616.92
TechInsights has presented their comparison table between IFS, SF and TSMC at 2024 SEMI International Strategy Symposium. IFS's process density as suspected is pretty low, that's why they don't win any major contract. I have calculated performance/power at the table above.
N3B's density is in fact denser than upcoming N3E due to multi-patterning solution. And that's why Apple will continue using it for M4 series cause M4 Max will likely pass 100 billions transistor threshold.
Reactions: Tlh97
Tigerick
942
858
During a presentation for investors, Chief Executive Pat Gelsinger said 2024 would be the year of worst operating losses for the company's chipmaking business and that it expects to break even on an operating basis by about 2027.
Here is the BS from Pat:
Gelsinger said the foundry business was weighed down by bad decisions, including one year ago against using extreme ultraviolet (EUV) machines from Dutch firm ASML. Partially as a result of the missteps, Intel has outsourced about 30% of the total number of wafers to external contract manufacturers such as TSMC, Gelsinger said. It aims to bring that number down to roughly 20%.
Anyhow, I have created a table to compare yearly revenue from 3 foundry. We should see how IF going to turn things around in 2030:-
Intel Foundry+/- MarginReport Loss Business to TSMC's N3BSamsung FoundryTotal IF + SF RevenueTSMC's Advanced Process (N7 & Below)
2022$27.49 billions- $5.2 billions$22.53 billions$50 billions$40.22 billions
2023$18.9 billions- $7 billions$16.77 billions$35.67 billions$40.16 billions
2024$17.6 billions- $13.4 billions- $4 billions$19.31 billions$36.91 billions$62.33 billions
2025- --$10 billions
2026- -NVL-S N2
2027- -
2028
2029
2030> SF
Based on revenue figures of IFS in 2023 ($18.9 billions), IFS should overtake SF already which has earned $16.77 billions in 2023. The reason behind is Intel going to order N3B wafers from TSMC this year. There is report about Intel going to spend $4 billions this year and $10 billions next year for N3B wafers. That's mean this year IFS's revenue should drop sequentially...
It also means the worst year of Intel Foundry has not come yet... :eek:
H433x0n
1,224
1,606
IFSIntel 3Intel 18A
Density143195
TSMCN3BN3EN2N2P14A
This is comparing the theoretical max dense library. So it’s comparing 2-1-fin cells against a 3 fin cell. A more proper comparison would be comparing TSMC’s 2-2 fin cell library that they use as standard for HPC against Intel’s 3 fin library used in Intel 3. When using that metric TSMC is still considerably more dense 182.5mtr/mm2 vs 143mtr/mm2 but it’s comparing apples/apples. These are the cells that would be used in AMD processors and Nvidia GPUs.
Tigerick
942
858
TSMC ProcessFeaturesHVM DateActual HVM's DateFirst Device ShippedProduct
N3EBaseH2 2023Q4 2023Q2 2024iPad Pro M4
N3PDensity +4%H2 2024Q4 2024Q3 2025iPhone 17 A19 Pro
N3XDensity +~14%H2 2025Q4 2025Q3 2026 ?Zen 6 CCD
N2Performance +15%
Density +15%
Base w/ GAA
H2 2025Q4 2025Q2 2026 - WWDC ?M5 Pro and Max ?
N2PPerformance +10%H2 20262027
A16N2P with SPR: Density +10%H2 20262027
N2X+10% Fmax20272028
A142nd Gen GAA
Performance +15%
Density +23%
20282029
A14 with SPRDensity +10% ?20282029
I have compiled upcoming 2nm process from TSMC. There are 3 variants of N2 family, once you know the differences, it will be easier to understand each node and delivery date. That's why the slide below seems contain lots of misinformation:-
Reactions: Tlh97 and Tarkin77
MrTeal
3,919
2,708
Jesus christ @ Bitmain. I know they're the 1000 lbs gorilla of Bitcoin mining, but the same number of 2nm wafers in 2025 as Apple is nuts.
It funny for as much as the goal of BTC was decentralization, pretty much every single transaction on the blockchain runs through equipment sole sourced from one Chinese company.
Reactions: adamge
FlameTail
4,384
2,762
MrTeal
3,919
2,708
Qualcomm is missing in that Trendforce chart. Any idea why?
Most sources have the same speculation as the article you linked; Qualcomm pivoting to Samsung.
Doug S
3,856
6,821
If that chart is correct then TSMC will only be making M5s for Apple in 2025. They sell more than 10 iPhones for every Mac they sell, so obviously that M5 volume would be a faction of their later volume with A20.
Tarkin77
98
208
N3EH2 2023Q4 2023Q2 2024iPad Pro M4
N3PH2 20242025
N2Base w/ GAAH2 20252026
A16N2P with SPR: Density +10%H2 2026 ?2027
Zen 6 and mi400 taped out already??
FlameTail
4,384
2,762
Pivoting to Samsung for flagship products sounds like a blunder to me. The last time Qualcomm did so, it didn't end well (888, 8 Gen 1).
If Qualcomm isn't using TSMC N2 (and that's a big if), then I think it's more likely that Qualcomm is pivoting to Intel Foundry than Samsung Foundry.
Samsung's nodes are lagging behind TSMC in all PPA metrics, and they also have horrible yield issues on top of that. On the other hand, it seems Intel 18A-P could match TSMC N2 in atleast some PPA metrics. There are doubts about Intel Foundry too, but it's looking much more hopeful than Samsung.
