rubbish. the TSMC 20nm node is just not suitable for high performance CPU and GPUs. Because even though transistor density is almost 2x higher than TSMC 28nm like a traditional full process node the transistor speed gain and power efficiency gain is minimal and more like a half node.
Perf at the same power (15% higher)
TSMC 20nm - 1.15x
TSMC 28nm - 1x
Power at the same perf (30% lower power)
TSMC 28nm - 1x
TSMC 20nm - 0.7x
With a traditional full process node gain we are used to getting a 40-45% speed gain at same power or a 50- 55% lower power at same perf. This is how TSMC 28nm HP was in relation to TSMC 40G. The primary reason for the above problem is planar transistor has run its course and is completely incapable of providing further speed and efficiency gains. For that FINFET is required.
The TSMC 16FF and 16FF+ are what we call a full process node leap from 28nm. 16FF+ is a massive leap as it improves on 16FF and provides a 70% power reduction over TSMC 28nm at same perf or a 65% speed gain at same power.
http://www.tsmc.com/english/dedicatedFoundry/technology/16nm.htm
This is why AMD and Nvidia have chosen to skip 20nm as it does not have the process node characteristics (transistor perf gain, power efficiency gain) required to manufacture power hungry and massive high performance GPUs. The chips manufactured at TSMC 20nm are all sub 5W and sub 150 sq mm chips. TSMC 20nm is just not suitable for 300 sq mm and 200W GPUs. We will get those next year at TSMC 16FF+ .
