Trying to share a printer between 2 XP systems through wireless router
sohcrates
Both running XP. Both are on the same workgroup name.
1 box is connected through cat5e to an Linksys router (from Vonage for VOIP)
a second box is connected wirelessly through an SMC barricade wireless router which is hard wired to the same Linksys router.
So basically, the second box is connected through a router plugged into another router.
We dont show up on the same network, so i cant seem to share printers (or files of course)
any ideas?
Easiest method.... shutdown dhcp server on your smc router(if possible) and run a cable from one of the lan ports on the linksys to one of the lanports on the smc.
You should now have a wireless ap + switch and both computers will be on the same network.
and voila. Theres the solution.
does the cable have to be a crossover or will straight through work?
