jitter1127
I am trying to do this for my neighbor, but I could not get it to work so i brought his AP over to try it at my house. It is an Encore ENHWI-N3 http://www.encore-usa.com/us/product/ENHWI-N3.
Here is the manual
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N3_UM.pdf
I have a comcast modem with IP of 10.0.0.1 . I factory resetted the encore, hooked it up to my PC / comcast modem via LAN Ports. I set the encore IP to 10.0.0.20, disabled the DHCP server. I then changed the SSID / password to match that of the comcast modem/router. I also disabled the NAT.
What I tried to do was to move the Encore to a different room and hook it up to my PS3 via LAN ports. My PS3 is not obtaining an IP address. So then I looked at the manual and tried to use the WDS mode. Here is what the manual says about that.
"Wireless Distribution System. The WDS is a way of interconnecting wireless routers and allow an extended wireless network coverage using multiple wireless routers without the use of a wired backbone. Each WDS AP requires the same channel and encryption type to work."
If my comcast modem is set to channel 1 does that mean the Encore wireless has to be set to channel 1 as well? I was also confused about the MAC address screen that came up.
It says "Please enter the MAC address(es) of the neighboring APs
that participates in the WDS. A maximum of 4 devices are
allowed."
Do I enter the MAC address of the WiFi LAN port on the comcast modem, or a MAC of something else?
Thanks for any help.
Here is the manual
allowed."
