Help Please!!
My system is at the moment running Windows ME. Iwant to do a format so that
it is cleared from the hard drive, and i have a windows 95 cd to load . When
windows 95 is loaded I have a windows 98SE cd to upgrade with- thus leaving
me with windows 98SE .
I have got a Windows 98 startup floppy disc, which should have the cd drivers
on it.
So I followed these instructions and it went wrong.
What do I do now please
?STEP TWO
Insert your boot disk in the floppy drive and start the computer. Once the system has completed booting
and an A: prompt appears we are ready to start.
Type: format C: /s [press Enter]
This statement tells the system to format your "C" drive and when it is finished to copy the system files
to the drive, (the /s switch for 'System'). You can format a different drive this way by using a different
drive letter.
Format should display: WARNING, ALL DATA ON
NON-REMOVABLE DISK DRIVE C: WILL BE LOST!
Proceed with Format (Y/N)? Type [Y] [Press ENTER]
Your screen should display the size of your drive and a countdown in percentage of formatting
completed. Depending on your computer's speed and the size of the drive it can take from a few minutes
to over 15minutes."
But it doesn't complete apparently - now I get the following
?Checking existing disk format.
Recording current bad clusters
5 percent completed.
Insufficient memory.?
Below it is the A prompt.
on it.
?STEP TWO
drive letter.
to over 15minutes."
 Facebook
Facebook Twitter
Twitter
