- May 4, 2002
- 3,344
- 32
- 91
I’d like to line the housing with something to reduce vibration noise, but figured I’d ask first if the exposed copper being in contact with the material poses any danger. Does anyone know if they get hot enough to do that?
The pump is a Swiftech MCP30/MCP50x.
Yes they do get hot... rediculously hot enough to melt gell isolation pad PetraTech used to sell.
This is why you see metal housing with heat sinks on them as options, and all my DDCs have aftermarket heatsinks.
If you want quiet, you should of gotten a D5.
I am not familiar with this pump, but my initial impression after seeing the pic was to agree with
thesmokingman. Yes you should dampen the chassis mounting.
However then I took a look at the pic again, it seems to have some outer cover over it. Is that outer cover what is vibrating against the main, lower portion? Is that outer cover required (for mounting) or just for visual aesthetics? If it is just to make it prettier, I'd leave the cover off as it is also causing an insulating air pocket that would make it run hotter still.
