I want to build an entry level gaming machine. I don't have a set budget, but the less expensive, the better. Basically, I want the best bang-for-the-buck machine. Heres my idea; It's very similar to Anandtech's buying guide for an "upgraded" entry level system.
Processor: AMD Athlon 64 3000+ 1.8 GHz 512KB L2 90nm socket 939 - $146
Motherboard: Chaintech VNF4 Socket 939 - $91
Memory: 2x512MB PDP/Patriot PC3200, Model PDC1G3200LLK - $131
Video Card: Leadtek GeForce 6600 128-bit 128MB PCIe 300/550 - $109
Hard Drive: Seagate 160 GB 7200 RPM 8MB SATA - $94
Optical Drive 1: NEC DVD+RW 3520A - $57
Floppy Drive: NEC, Sony, TEAC, Samsung, etc. - $8
Case: Not sure. I think I'll just go down to Fry's and pick up a full tower.
Power Supply: Enermax Noisetaker 370W model EG375P-VE-SFMA - $51
Display: Cheap, used one at first, no more than $40
Speakers: Cheap ones, no more than $20
Keyboard and Mouse: Fry's, whatever is comfortable.
Bottom Line: $687 w/o display, speakers, case, and kb/mouse.
Thank you for your input.
