Trying to Help My Dad Restore Emails in OE6
Caveman
2,537
34
He went from Win98 to 2000 and has all his .dbx folders stored on his new machine already... The problem is that he can't get them to import into the new install of OE6... We tried a procedure similar to the one below... All seems normal until we do the last step (in the last sentence) Although all his .dbx folders are indeed there in there in the store directory, only the inbox, outbox, and sent mail folders show their availability in the "window" as selectable and will be imported leaving all the others behind...
Anyone know how to fix this?
How you can move your messages between two different computers that are running Outlook Express. (MS Support Doc ID Q257499)
Use the following steps to move your messages between two computers that are running Outlook Express:
Click Start, point to Find, and then click Files Or Folders.
In the Named box, type *.dbx, and then click Find Now. Note the path of the file name and location of your mail folders. These are the files that end in *.dbx.
NOTE: If you use identities, each user has their own mail folder.
Copy or back up the mail folders to your backup media by using your own backup program or Microsoft Backup (MSbackup) that is included with the operating system.
NOTE: If the size of the mail folders are less than 1.4 megabytes (MB), copy them to a disk one at a time, and then move them to the second computer.
Create a folder called "Mail" (without quotation marks) on the computer that is receiving the transported mail folders.
Restore or paste the mail folders into the Mail folder that you created. Note to include the Folders.dbx file when you copy from the first computer. This file is necessary for the import functions in Outlook Express.
After you have moved all the mail folders, including the Folder.dbx file, to the second computer, use the import function in Outlook Express.
Start Outlook Express.
On the File menu, click Import, and then click Messages.
Click Microsoft Outlook Express.
Click Import mail from OE store directory, and then locate the mail folder that you created.
When you are receive the prompt to select the mail folder that you want to import, click Import all of the Mail Folders listed. This merges e-mail messages into any of the default folders and creates all other folders that are not default on this computer.
Renob
7,596
go into the new folder and rename the inbox, sent. and deleated dbx files by adding a 1 to them. then bring in the old dbx files one at a time using explore and that should work.
