The title is not quite accurate. I have a wireless LAN which four Windows XP computers share, meaning I can mark a folder to be shared on any machine and all machines can access it.
I bought a Toshiba Satellite C55 B5202 laptop running Windoes 8.1 which immediately found the LAN -- shows five bar strength -- and uses it to access the internet. Getting very good speeds both up and down.
I would like to add the laptop to the network so it can share files with the other machines. I know how to do that in Windows XP and have done it for dozens of machines over the years, but after hours of poreing over the Toshiba manual and reading on internet am unable to make the laptop "join" the workgroup. All I can reach at Toshiba tech support is an automated query response that is totally dedicated to getting on the internet. But I am on internet and have been from the beginning. What I need to do is cause the laptop to become a member of the existing workgroup.
Is there a site that has simple instructions for causing a Windows 8.1 laptop to join a workgroup?
There is a lot at stake -- for me -- in getting this done. My NAS is based on a couple of Netgear SC101's which are incompatible with Windows 8.1 and which Netgear has said they will nor provide new drivers for to make them compatible. Since all four of the Windows XP machines read and write to the SC101's with no problem, a workaround would be to create a shared folder on one of the XP machines and use it as an intermediary to move a file to and from the laptop on those occasions that is needed.
Thanks
Thanks
