Originally posted by: radioouman
I'm sure that you can find them from a Haynes manual.
But here's a start:
Upper ball joints
Lower ball joints
Inner and outer tie rod ends
I don't know what kinds of steering it has, but it may have one at the pitman arm and the idler arm. If the driveshaft has a slip-spline, you may have one on the housing of the driveshaft. You might also have them on the u-joints in the driveshaft.
But here's a start:
Upper ball joints
Lower ball joints
Originally posted by: Dirigible
My mountain bike frame has five zerks. I grease 'em every month. Dunno how many your car has. 😛
iamaelephant: I dunno what a grease nipple is, but it sounds like the same idea. A zerk is a little fitting. You put your grease gun to it and pump some grease in.
