Trying to figure out how to get fan filters for my radiators
Masahiro
How's it going guys?
I have a LD Cooling V8 (http://www.ldcooling.com/shop/big-t...57-ld-pc-v8-reverse-atx-hptx-black-white.html) with one 4.120 EK rad up top and two other 360's at the bottom. The problem is that I have a cat, and as a result I need to clean the case out every month or so because it has all of these vents. I was wondering if anyone had an idea of how to maybe get some sort of filters over the grills so that dust and dander don't get in so easily. If anyone has any ideas I would be eternally grateful 😛.
There are a lot of filters you can choose from here. I use this for my personal rig and I have 4 of them, 2x120mm affixed to the radiator with screws, I brush off the collected dust every week or so and another 2x140mm on the side panel attached magnetically which I can remove the filter and wash it if needed.
I have a DEMCiflex 360 filter for my top rad. it does a great job
That's perfect billyb0b thanks dude. Before I go ahead and order, do you know of any other companies that make these extended length filters other than DEMCIflex? I just kinda want to see if there's others out there that have em in different colors 😀, I feel like white fan filters would go well with the white interior of the case but if not whatever.
EDIT: NVM just gonna go ahead and grab those filters, thanks again for pointing them out
