Trying to extend wireless signal at farm -- Antenna booster or try a Repeater?
Claudius-07
187
Good morning. I am trying to decide on a solution for my father's rural small farm. He does not get any sort of actual high speed INTERNET out there. I have tried calling every possible solution (Canada here), and really the only option, which we went for, is using a Fido Hotspot device. It's got its own data plan/SIM card. It's a small device, he can connect 10 devices to it, works like a router really. Anyhow here is my problem.
The device sits in his "small office" in the main house. His barn is like freaking 200 feet away at least, maybe more. His workshop is 110 feet the other way. Christ. He spends most of his day back and forth. My mom is back at the house where the internet hotspot is smack in the middle of the workshop and barn. They insist on the hotspot thingy staying in the main house, which makes sense but my dad wants to have internet in his workshop and then have access at the barn as well... grr.
How do i get the wireless signal from the main house to reach all the way to workshop and barn? I tried walking around with my cell looking to see if i could pick up the wireless signal and maybe I could see it from the 110 foot away but that was spotty at best. And nada at the barn.
My options so far are:
The Fido Hotspot device has two slots for some sort of external antennas. I googled it and on ebay found a few options which some are directional some are wide coverage. I am not sure if I should get two of these external antennas. Here is one of them:
or
[URL="http://www.amazon.ca/Wireless-internet-External-Magnetic-Antenna/dp/B005SLV8MA/ref=pd_sbs_107_5?ie=UTF8&dpID=21cUbEOp6yL&dpSrc=sims&preST=_AC_UL160_SR120%2C160_&refRID=0AVX41XH33HCT3CPD6AH"]
What I don't understand and I apologize for being dense, are these to increase the range the device SENDS out (so to connect devices which is what I want) or are these antennas to RECEIVE a better cell signal for the device??
OR should I buy an additional router (which I am told should be a repeater or an access point not sure which or if that is the same). I went to my local computer store and the dude there said buy a good AC repeater/router and place it mid way. Mid way is in a field or do I buy two repeaters? So do I run a power cord out 150 feet out in the field and build something to protect it from the winter and snow?
I just don't know.
What about somehow connecting the hotspot to a switch/router and running 100 feet and then 200+ feet of network cable to the workshop and barn?? LOL. Can i just do that?? can Ethernet cable go that far? If I could do that it might be better even cheaper. I would need to bloody bury the wires though. Sigh.
Last summer I was at a fishing camp for a week. The main office had a dinky Dlink router and our cottage that we rented was freaking far away and i could get wireless. The guy there told me his dlink wireless router is nothing fancy. How the heck was he getting such coverage? it's pretty much what I want to do for my dad.
smitbret
3,382
17
if you can bury wire, that would be the ideal situation. Gigabit Ethernet segment can be up to 100M so you should be fine.
failing that, you can use wifi bridge, assuming you have good line of sight, something like this
http://www.amazon.com/gp/product/B0...wifi bridge&qid=1448293431&ref_=sr_1_1&sr=8-1
and a wireless access point in barn.
Yep, 200 feet is nothing. I would probably just go with the wireless bridge and a cheap $20-30 router converted to an AP. Probably come out cheaper than the materials needed to bury a cable and a whole lot easier.
Claudius-07
187
Thank you sdifox and smitbret
Wow don't know what to say. I looked at the link you provided sdifox, the Ubiquiti wifi bridge is simply incredible. I had NO idea you could get something that can transmit WIFI that far. So instead of buying a crazy (hoping for the best) $270++ Wifi Router hoping it could transmit that far, which it can't, or digging 200 feet one way and 100 in the other way, i can spend $100 for this Ubiquiti bridge but then i would need to either buy another one and set it as a "receiver" or what you guys are calling an Access Point? Or as Smitbret said, I don't need to buy two of these, i can buy one and then find a really cheap router that offers to the option to be used as an AP right? So I could buy something like this and set it up in AP Client Mode:
http://www.amazon.ca/TP-Link-TL-WR7..._cp_147_3?ie=UTF8&refRID=10HSBXAFW8DDY9XY4Y1B
I mean I scrapping the bargain bin here. Maybe there are better ones but I found that one right away.
sdifox
100,361
17,924
A pair of the nanostations = that buried Ethernet cable. You still need an access point in the barn to provide wifi. You can use a cheap router that can run in AP mode or get an access point. The thing you linked is not the right type of product.
smitbret
3,382
17
I have never used the Ubiquiti Nanostations that SdiFox linked but I have a similar setup between my parents house and their calving barn about 1/3 of a mile away. SDIFox wouldn't recommend it if it didn't work, though. Any antennas that are directional will provide pretty good range between them. For covering 200 feet, some Cat6 buried in some electrical conduit would be more reliable and maybe faster but I don't know that it would be worth digging a trench, laying the conduit, etc.
Either way you need an Access Point on the back end.
Something like this:
http://www.amazon.com/NETGEAR-Route...8&qid=1448306061&sr=8-1&keywords=netgear+2020
You'll connect it to the 2nd Bridge or the cable end in the barn. You'll have to set up your wireless network and turn off DHCP and NAT. This guide is pretty good:
http://www.ezlan.net/router_AP.html
Any wired devices will attach there, too. You don't need a repeater. They just pick up an existing wireless signal and retransmit it. You will lose at least half of your bandwidth doing that, though and it won't be nearly as reliable.
