Trying to control fan speed
fd9
29
I have a 3-pin fan and a 3-pin connector on my motherboard. It's the fan that came with my case so it's probably a cheap brand. The fan is plugged directly into the motherboard, not the PSU. I have a GA-P35-DS3L motherboard.
So basically my question is this: Is it possible to automatically control the fan speed if it's a 3-pin connection, or do I need a 4 pin connection?
DerwenArtos12
4,278
The bios on your motherboard should be able to control the fan speed through the use of gigabytes control program.
sutahz
1,300
Yeah.... we need more info. Take a pic of your mobo, or find a pic of your mobo and edit it to show where the fan is hooked up to. I'm willing to bet your mobo can only control the speed of 2 or 3 fan headers on your mobo (NB, CPU and maybe something labled like Chassis or System 3)
fd9
29
There are a total of 4 fan headers on the mobo (including CPU). The BIOS setting only works for the CPU fan, and I didn't have much luck with SpeedFan, so my question is: Can SpeedFan control a 3-pin fan, or does it need a 4-pin fan, or does it depend on the make/model of the fan? I don't want to go out and buy another "quiet" 3-pin fan just to find out that it's going to run at 100% constantly.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Three pin fan = set bios speed control to DC
Four pin fan = set bios speed control to PWM.
