- May 16, 2005
- 4,649
- 1,018
- 136
And I can't get it to work. I downloaded the official drivers from MS but all my controller does when I hold the middle button is flash all 4 lights over and over. Anyone know what's wrong?
It's a controller with a play and charge kit. Googling tells me it's very much doable.
Well shucks then. The driver even says "Xbox Wireless Controller with Play and Charge Kit"
it's a stupid rule that makes no sense.
Well it's not really a rule. The wireless controller transmits no info over the wire, only over wireless. That's how they made it.
You shoulda got the wired controller. No battery to worry about and it always works fine.
Not to mention cheaper.
Yeah it's M$ afterall. The PS3 controller works with the USB charger, but no drivers for it except 3rd party one's (MotionJoy).Well it's not really a rule. The wireless controller transmits no info over the wire, only over wireless. That's how they made it.
Which works great for many older games, but most newer one's are setup to automatically use the 360 controller if connected.Get a PS3 controller and use MotionJoy.
As SpaciallyAware wrote, you need to pair the receiver and your pad. Press the button on the receiver until it blinks, there's also a small button between LB and RB on the pad - press it next. Then the devices will link and you can use your pad. You only have to do it once. Of course if you pair the same pad with an Xbox later (button on Xbox + button on pad), the setting will be cleared and if you want to use it on PC again, just pair it again with the receiver.
If it won't sync then it's defective.
Is this where you got the drivers?
http://www.microsoft.com/hardware/download/download.aspx?category=gaming
