My ceiling budget is 2k. I don't want to exceed 2k. I also want to go for best bang for buck. Just because I have my budget at $2k doesn't mean I want to reach it.
Goal is playing max settings with eyefinity and 30" u3011.
I chose AMD over NVidia because of the high resolutions I am playing. The 2gb simply wins at high resolutions.
3x 2408WFP's (1920x1200) and 2560x1600.
This rig will be used ONLY for gaming. Nothing else.
Anyone have some input? I was planning on ordering the parts before Sunday so I can get them shortly after I pick up the CPU at Microcenter.
I think Microcenter will have best CPU prices ($70 cheaper?) So everything but the CPU I'm getting online.
https://spreadsheets0.google.com/cc...authkey=CMbIrqQE&hl=en&authkey=CMbIrqQE#gid=1
Concerns:
1) Not sure which motherboard to get. I think I want the asus p8p67 Ultra. I was thinking about the p8p67 Sabertooth (I like the shroud).
2) 1333 DDR3 vs 1600. No difference on Sandy Bridge right?
3) Does it make more sense to get 2x 6970's over 2x 6950's? I don't want to void warranty by flashing the 6950's in case I sell it in future so I can upgrade quicker down the line.
4) I need a white case, that's why I chose the phantom.
5) What's best modular PSU between 1000w-1200w that will last me a couple builds but not break my bank?
6) NEW SSD's announced at CES. Should I wait until those new SSD's come out before buying current ones?
7) Caviar Black best HDD to buy for now?
8) Planning on overclocking CPU to 4.6GHZ with stock heatsink (many reviews said you can get easy overclock on the new SB processors with stock heatsink). [h] review said this too.
Concerns:
