Trying to be a Cardinals fan....
ktehmok
4,326
I'm not trying hard enough to warrant buying any shirts or hats or anything but..
I live in Phoenix, and I have been trying for ten years to be a Cardinals fan. I'm a Steelers fan from birth. Through their good & bad. I figured I would at least try to support the local team, but christ, they're horrible. It's like, as soon as the season (or pre-season) starts, the Cardinals put on their shoulder pads, then climb under the desk that is the rest of the NFL and start sucking...
The really bad thing is that these bums get paid as much as real NFL players...
NTB
5,179
Maybe it *was* a good thing that they moved.... :p
/me lives in St. Louis
Nate
chuckywang
20,133
Keep trying, bandwagoner.
ktehmok
4,326
Not sure where that comment came from. "Bandwagoner"? If you're referring to the Steelers..fvck you..sideways with a post hole digger. It you're referring to the Cardinals....umm what?
Think before you post.
JulesMaximus
74,567
969
Good luck with that. I know people who've lived in Phoenix for years and still have a difficult time rooting for the Cardinals.
chuckywang
20,133
I have. You freely admitted you didn't like the Cardinals because they are so bad.
ktehmok
4,326
What the fvck does my post have to do with jumping on a bandwagon? I stated that I am trying to be involved in, and trying to support a local team.
Jumping on a bandwagon would be going out & buying Patriots gear and touting how great they are. Go look up the definition if it's that confusing.
You still make absolutely no sense. And you clearly did not think before you posted.
chuckywang
20,133
If a team is horrible, then you do not root for them.
Contrapositively, if you do root for a team, then they're really good. Therefore, every team you root for is good, hence you're a bandwagoner.
ktehmok
4,326
Contrapositively? Try using a real word, like "contrapositive to your argument"?
You still didn't make any sense. Can I have some of what you're smoking/drinking?
Keep talking though, you'll make lifer in no time! No one said anything you post has to be intelligent.
