Trying to auto-repair WinXP Home
RMSe17
A friend of mine gave me a laptop to try to fix. It has Windows XP Home installed, apparently the Korean version if there is such a thing, because when I turn it on, and see the Windows screen with selection for Safe mode, etc.. it's in Korean.
The problem is that no matter which selection I make, the result is a blinking cursor at the top with black screen. Windows never finishes loading.
From what he told me, they were watching a movie on it, and then the laptop turned off, and then never turned back on successfully. So I figure some windows file corruption, I boot of a Windows Home cd, go to Console, and run the disk check, which says it fixed something. However, still a no go. So I figure ok, the CD key is written on the bottom of the laptop, so I can just do a recovery with my XP Home CD, and then somehow change language to Korean if it comes up as US.
The problem is, when I click Enter to install XP, and it says "Searching for previous installs of Windows" it goes straight to selecting C or D drives or partitioning it otherwise, and does not ask me if I want to repair that install..
Any ideas?
Thanks!
Thread moved from Software For Windows to Operating Systems.
AnandTech Moderator
mechBgon
Windows installation is probably so corrupt that setup doesn't see it. If that the case you may need to do a fresh install of windows.
Well I know accessing your registry for one to get info for setting up repair from the command prompt or doing a repair install. I have had a few systems in the past like that and if it cant be read it properly it just trys to do a new install
It wasn't the windows installation that was corrupt, it is apparently the inability of regular Windows XP Home to see or repair the Windows XP Home K or Windows XP Home KN versions. I was able to find the ISO's for K and KN versions, and they both saw the existing install, and went ahead with the repairs. Unfortunately, I am still stuck, because the CD key is an OEM key, but the only ISO's of Windows XP Home K and KN that I could find anywhere are the Retails, which don't accept the key. Can not locate Home OEM K anywhere 🙁 Rather frustrating.
Have you tried a US OEM CD to see if it might work. I No idea how the serial is made. Is it justing look for type of install e.g. OEM RETAIL VL ect. or if its checking for a country code no idea.
