Trust Thermaltake?
Sniper82
16,517
I am buying a used Thermaltake case with Thermaltake 420watt PSU. I plan on upgrading to a NF4(not sli) mobo,Athlon 64 3000+,6600GT,2x512mb PC3200,1 HDD,2 optical drives,ect very soon.
Should I trust this PSU? Or should I consider something else? Hate to spend anymore then I have to. Right now I prob won't o/c but will def o/c on down the road.
Mik3y
Banned
Mar 2, 2004
7,089
i'd find taht the thermaltake psu tends to "overexagerate". i recommend get a better psu, tho that psu will be able to support your current specs at stock.
mauiblue
652
I'm using a Thermaltake 420 watt PSU and case. It has been in use since I've built it last July. No problems or hiccups. But I am *hoping* to upgrade to a X800 XT PE card (as soon as CDW will fill my backorder which is going on three months now:shocked: ) and adding cold cathode tube lights so I upgrading to a better PSU namely PC Power & Cooling. I bought the Thermaltake case with the PSU because it was a great deal at the time. But if it wasn't for all the additional hardware upgrades, I would been satisfied with the Thermaltake PSU.
