True vertical monitors?
14,081
Lot of monitors can be oriented so they are vertical, but that requires the driver to also support that, and to flip within the OS. So if you are viewing the bios, or a live CD, or anything not part of the primary OS, it will be 90 degrees off. Even within Windows there will be things like power point presentations, games etc that wont show up properly.
Do they make monitors that are actually natively vertical? I hate how all newer monitors are wide screen now, that cuts out on the amount of vertical area, and makes it take up more room. I plan to later on go with 3 monitors, but with wide screen I would have no room, so I'd want them to be vertical.
At work I have 3 that are vertical, but it's "faked" using the orientation setting of the driver, and it can be a real pain sometimes. I can't open anything such as a powerpoint presentation or all the icons get scattered all over the place, the other two monitors screw up etc... I'm hoping there are monitors that are this orientation natively so there's no "middle man" (the driver) involved, and no OS dependance. So is there such thing?
Also, a side note, but how do people with 3 or more monitors deal with it? I find Windows has lot of trouble with it, and often screws up. Like after a reboot usually everything resets and has to be reconfigured. Sometimes one or two of them wont even turn on and have to be reenabled, the icons are always all reset etc... maybe Linux is better for this? I do plan to switch to Linux eventually, so maybe that's my best bet?
OVerLoRDI
5,490
4
I'll agree with you on the Windows still being stupid about multiple monitors. I run a 3 monitor setup, but none of them are vertical.
I'm also willing to bet that there are no consumer monitors that are natively vertical, as you are describing.
Final8ty
1,172
13
I use PLP 1600x1200 2560x1600 1600x1200 and i don't have a problem of windows forgetting the orientation.
http://img253.imageshack.us/img253/3797/dsc00020xt.jpg
Pia
1,563
IMO, "native vertical" should also have its subpixels oriented differently. That would give you more effective resolution if you use subpixel rendering on the desktop (due to our internal "image processing", we benefit much more from horizontal resolution).
But no, there aren't any.
dawza
921
Within Windows at least, I've had no issues with NV drivers and orientation, from XP to Vista to 7. It's pretty much a set it once and forget it affair. However, I also never run portrait mode in solo config-- so I always use some kind of management utility (UltraMon or, more recently, DisplayFusion).
DisplayFusion does a great job for configuring window placement, orientation, movement, wallpapers, taskbars, etc. I've never had any odd issues in years of use due to rotation or physical placement/location. I usually combine this with WinSplit Revolution to hotkey window placement.
I have no solution for config outside of the OS, unfortunately. I run a 2560x1600 in landscape with a 1600x1200 in portrait, so I always have a "standard" monitor to fall back on.
14,081
Nice setup, that might actually be what I'll do, keep a really big monitor in normal orientation as the #1, that way non OS specific stuff will display properly, then I can use the other two as #2 and #3.
That way when I boot off a CD or whatever, it will be oriented normally.
I kind of figured there was no native vertical monitors, as I have not found any. I guess the market is just not big enough as most people (as in non techies) just have a single monitor.
Stuka87
6,240
2,559
Final8ty: Thats a cool setup.
As for windows and multiple monitors... its horrible. I need to use special software just to be able to set different backgrounds on each display. I have been able to do this on my macs for well over a decade now without any added software.
I have run multiple monitors (either 2 or 3) for about the last 12 or so years. And it has always been quite aggravating when done on Windows. And yes there is software to do most of this, but I should NOT have to buy special software to do what the OS should do on its own. Especially when other OS's have been doing it for so long.
Final8ty
1,172
13
Its near perfect for Eyefinity as far as screens goes as the boarders are on your peripheral vision and not in your face, pictures or videos never do it justice as you totally lose the scale of how big the center screen is, pity i have to game in windowed mode to get the games across all 3 screens or HTSoft and lose quadfire power.
Phenom II X6 1090T 4Ghz NB 3Ghz
NEC's 2560x1600 2x1600x1200 PLP 4960x1600
2x5970 Sapphire Toxic 4GB 900/1200 Quadfire
16GB Ballistix Tactical Tracer
OCZ Vertex-3 240GB
WD 6x2TB in RAID-5 10TB
Corsair AX1200 PSU
X-Fi Elite Pro
RavenSEAL
8,661
Its near perfect for Eyefinity as far as screens goes as the boarders are on your peripheral vision and not in your face, pity i have to game in windowed mode to get the games across all 3 screens or HTSoft and lose quadfire power.
OCZ Vertex-3 240GB
Corsair AX1200 PSU
X-Fi Elite Pro
Damn, nice rig. Pics please? :D
