Going by the wattage of the bulbs I currently have 300 watts of lighting for my aquarium. I'm thinking of upping it to 450+ watts. This seems like an insane amount of power usage but I know PCF are more efficient. So my question is, are my lights really drawing that much power? If not, is there a way to calculate it? TIA.
Reef Geek reporting in!
In order from lowest PAR (
http://www.hobilabs.com/cms/index.cfm/37/1288/1301/1407/3241.htm) output to highest:
NO T8>NO T5>Power compacts>HO T5/Metal Halide/VHO T12 (the last 3 are pretty much a tie...).
Instead of jumping up to 450 watts of power compacts, you should be looking at upgrading to T5's if you want to stay with fluorescent tubes. Lower energy usage per foot, double life span compared to power compacts, better bulb selection, nicer fixtures, ect...are all good reasons to move too T5 HO's from something else.
What size tank? Im actually running 440 watts of T5 HO over a tank....its a mammoth fixture (28" wide), but it lights it up and makes my house glow
Also as for the "True power usage" question. IME, flourescent ballasts are anywhere from 60-80% effecient. So if the bulb is 65 watts, the ballast is drawing around 80 watts from the wall. Rough guess....buy a Kill-A-Watt to measure for your self.
