TRUE dual fan test results
BassBomb
8,390
TRUE isnt very restrictive with its fins so two wont really improve it much
always fun to try :)
Old Hippie
6,361
Other tests I've read came to the same conclusion.
I put a 120 X 38mm on mine and it made a 5 deg. temp. decrease all the way around.
aigomorla
21,042
3,522
you could probably mirror the static effect off that using 2 low speed yates.
This is why people do push and pull config.
You dont put 2 high static fans in push pull though a low restriction sink. Thats just stupid.
You use push pull on 2 quiet fans so you can cheat that static pressure requirement while not breaking your ears.
Old Hippie
6,361
Oh No, two of those crappy fan clips were enough to deal with.
My alcohol consumption would probably skyrocket if I had to deal with 4! :laugh: :beer:
aigomorla
21,042
3,522
ROFLROFL!!!
