- Jun 7, 2003
- 5,334
- 3
- 81
I have a 1998 Dodge Ram 5.2L , auto transmission. The truck overall runs decently, but it's a little annoying how it won't start moving unless I press the gas pedal. For example, backing up out of a parking space, I shift it in reverse and it sits still as if it were in neutral, and when I give it the right amount of gas it backs up fine. Same exact behavior goes with going from stop to moving forward it won't drive idle unless I press the gas pedal. Is there anything I can do or check? Thanks.
