truck question - what does 1/2 ton, 3/4 ton mean?
Banned
Feb 17, 2003
1,948
obviously not the weight of the truck, not the amount it could tow. is that the load it can carry in the bed?
Rallispec
12,375
10
Originally posted by: SammyBoy
I reckon it is.
So those huge trucks (f350 and such) can't even hold 2000 pounds in the bed?! what if they want to haul a load of gravel or something--- seems like that would weight a lot more than a ton.
Iron Woode
31,351
12,844
That's payload capacity, dude.
Iron Woode
31,351
12,844
I reckon it is.
F350 is a one ton payload truck. So is a Dodge 3500 series.
Those are huge trucks by the way.
HonkeyDonk
4,020
I reckon it is.
you still haven't answered his question.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
It's just a naming convention. Even the "half ton" F-150's can haul more than 1,000 pounds in the bed. At one point long(ish) ago I think those designations actually did coincide with payload capacity but as newer models were introduced the designations stuck even as payload capacity increased.
ZV
Banned
Feb 17, 2003
1,948
wow, half ton is only 1000 lbs. isn't that kinda low?
i can cram about 5 guys including myself in my civic plus cargo and we'll almost be at about 1000 lbs.
Apr 5, 2000
13,256
I reckon it is.
Nice to see that you haven't contributed/attempted to answer the question either
Well if you go over your payload capacity obviously bad things will happen to your suspension - shocks, springs, airbags, etc. Like Zen said, they obviously hold a lot more now - it's just naming convention. If you need to haul that much you'd get a trailer, or a F350 with a flatbed instead of a normal bed, thereby negating your problem
Edit: from what I can tell, actual payload is calculated by the GVWR - weight of the truck.
KenGr
725
If you look at the actual official literature, the 1/2 ton, 3/4 ton etc. doesn't appear any more. There was a time, many years ago, that those were approximate capacities but they are much higher now. The allowable load depends on which model of truck you get, which payload package, which optional equipment you have, etc. The payload includes the passengers as well as anything in the bed. I did a quick search and found that the 2002 F-150 could be optioned out for capacities of 1400 to 3100 lbs. Interestingly enough, 4 wheel drive versions have lower capacity because of the heavier chassis.
The "1-ton" F-350 can be outfitted to reach a capacity of almost 3 tons.
Here is a "Click and Clack" column on this:
Half Ton Trucks
BAMAVOO
41
Bahh. I have seen 3/4 ton trucks haul nearly 7000 lbs. My weak old 87 Bronco easily hauls 3500-4000 in a trailer. My boat was 2400 lbs and I pulled it all over the place with ease.
Acts837
1,072
first someone posts they don't know what a chevelle is -- and now this -- What kind of a world do we live in?
guyver01
22,135
61
Pickup Trucks are available in different load carrying capacities. Compact Pickups often feature 1/4 ton (226Kg) capacity while full size Pickups feature 1/2 (453Kg), 3/4 (680Kg) and 1 ton (907Kg) capacities. When Pickups are in use they tend to be either lightly loaded or loaded to capacity. Also, because it is easier to "overload" a Pickup Truck than a passenger car, the tires are more likely to experience more stress.
LAUST
8,957
LOL, don't be silly :p
The payload of a 1500 (aka 1/2 ton) GMC 2WD longbed is 2114lbs... now you may drive through :)... and if you want put the Civic in the bed of my truck :D
brigden
8,702
A world where some people couldn't care less about cars; including people like me.
Apr 5, 2000
13,256
Did you even read his question? Payload capacity != towing capacity. Try dumping 7000lbs into the bed of that 3/4 ton truck.
The maximum payload (factory specs anyway) is base GVWR - base weight
Hoober
4,425
65
It also depends on the engine.
The weight capacity on my 7.6L turbocharged V8 Diesel F250 is 20,000lbs.
But you need to look at how you're connecting your trailer or whatever you're haulilng. I don't know a hitch made that can take that kind of stress, so you have to look at a fifth wheel.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
A trailer is not the cargo bed. The 1/2, 3/4, and 1 ton naming conventions are from a time when they denoted a truck's cargo bed carrying capacity. When towing a trailer, only the tongue weigh contributes to GVWR and proper tongue weight on a 7,000 pound trailer is "only" about 700 pounds. You'd need a 1-ton truck with the flatbed option to get 7,000 pounds of cargo bed capacity.
ZV
Apr 5, 2000
13,256
Very true, I just meant as a generality. By 7.6 do you mean 7.3L diesel? (6.0 current, 7.3 former, and 6.9 before that)
