Truck door and wind problem
Saga
Banned
Feb 18, 2005
2,718
I'm.. genuinely surprised I'm not the only one. I've experienced this with three different truck models in my life and dealers always told me I was making it up. Considering two of these trucks were luxury vehicles I would have assumed they were built better.
Oddly I only ever notice it during the winter.
MovingTarget
9,002
115
Wind noise? You probably want to check your weather stripping along the doors and windows. These can be replaced somewhat easily (if you can find the right kind) and will drastically reduce wind noise if they are deteriorated. This is pretty common in older vehicles...
Saga
Banned
Feb 18, 2005
2,718
Mine is an 08. =P
Kirby
12,028
Just apply a thick layer of Liquid Nail along the outside of the door.
Josh123
3,030
I contacted a Dodge dealer and they said they could order the lining for $58 each and they guy I actually talked to did it to his truck not to long ago he said.
Black88GTA
3,430
Wind noise or road noise? There is a difference. Your tires can cause excessive road noise. Wind noise - not much you can do really. I guess you could try to Dynamat the hell out of every metal surface in your car under the carpeting / trim panels and replace all of the outer weatherstripping / sealing.
LTC8K6
28,520
1,575
Try installing those window vent shades. They can alter the air flow and perhaps modify the noise.
