Truck Advice
Kalbi
Banned
If you had to choose from Ford F150, Chevy Silverado, Dodge Ram, or Nissan Titan, which would you guys get? I'm hoping to start a Real Estate Development company in a year or two so the truck's use will mainly be for lugging construction stuff. Also if I missed a truck in it's class feel free to mention.
Edit: Anyone find spyshots of the new Tundra (2006?)?
I'm a Mopar guy, so I would take the Ram.
I'm not impressed by the Chevy. I have never been in a new F150 but the older ones seemed OK. I'd probably consider the Titan if my employer still offers a Nissan discount.
I would go with the Titan but after the poor performance it had crashing through airport fences it kind of lost it's appeal.
I think the chevy looks like ass with that chrome strip running across and the super tall/huge F-150's seem like a waste to me...
I'd probably go with the tundra.... or the heratige f150
but then I dont know much about trucks
Tundra Double Cab. Very very nice truck. Best of the bunch IMO.
If you need to tow heavy loads or haul near the maximum capabilities of the truck I would get the Titan but otherwise definitely get the Tundra.
Trucks last a long time, so if you really are going to use this to haul stuff or tow stuff I would think twice about getting a 1/2 ton pickup.
then wat should i get?
The Nissan or Toyota should not even be considered for construction work. They're not even in the same class as the others. I personally would go with the Ford.
That depends entirely on what he's hauling...
Ford F250 or F350.
Why? We have used 1/2 ton pickups to pull tons of stuff, the largest being a car hauler which is a 16' tri-axle trailer with electric brakes. Unless you're talking 5th wheels etc, a 3/4 ton or above is a gas hog. And even then, I would consider a diesel. If you're thinking of a 3/4 ton or above, then your poll is irrelevant, and you would have enough experience to make your own decision on this.
I would venture to guess a 1/2 ton is what your looking at, based on your poll and questions.
i guess i didn't make clear it's probably not for heavy duty stuff. I'll be subcontracting most of the work, and I want a "company truck" to expense. Use will be for light duty. I will be developing Single Family homes.
If you're going to be lugging alot of stuff, definately look into going to a 3/4 ton and consider a diesel. My uncle has over 300,000 miles on his '94 Ram (3/4 ton, diesel 4x4) that he uses to haul his tools around (carpenter) and it's still going strong.
All I said is , think twice, about what you, or people you work with, are going to want to do with this truck, over a period of time, not just at the beginning of your company.
That doesn't mean you need anything but a half-ton, but so far you haven't been very forthcoming as to what you really want the truck for..
You want to be the guy that pulls up on the jobsite with some blueprints, and donuts ?
Or are you going to use the truck as a truck ? Originally you said "lugging contruction stuff".
Do you mean everyday or very rarely ?
Equipment, or materials ? or both ?
insulation ? wood ? paint ? flooring ? soil or plants ?
Every day, or once a year ?
I'd get the Titan. I test drove all of the above trucks and it was a no brainer for me. Got a Crew Cab xe for 21k and I love it. Fast as hell and has a huge rear seat to boot.. The bed is a bit small(5.5 ft), but then again, the other CC's are not much bigger. If you looked at the King Cab, they have a 6 ft bed. Nissan seems to be underestimating the power of the engine in this truck. I ve read that people are getting close to 250 hp at the rear wheels which would mean around 335 hp at the crank. Thanks Nissan!
Peace
Lounatik
Agreed...I have an 03 (Access Cab) and love it!! 😀
The Toyota Tundra would be perfect for those needs.
damn, you nailed it. I was thinking mbz or a jag, but driving up in a truck serving donuts to the day laborers just seems more cool.
Out of the bunch, the F-150's and the GM trucks have the best bargains going on them currently. Out of those two, I think the F-150 is a better vehicle and "fresher".
You can get some serious deals on Ford and GM trucks at the moment. I like the Titan and the Tundra as light duty weekend runners, but I just don't see them as somthing I would beat on for construction purposes. I've never been a Dodge fan. Ever.
I had a 2000 GMC Sierra, the same truck as a Chevy. (Don't let anyone tell you it's really different, the front and the option packaging is different, but there's less than 100 bucks difference in price for an identically equipped truck) I had it for almost three years and liked it a lot, I would still have it if I hadn't been in a big wreck in it. It was never the same after that, and I traded it for my 2003 Dodge Ram, hemi,of course. It's been a very good vehicle so far, just past 2 years old. Only problems have been a stuck tailgate latch (They actually overtightend a collar on the one latch rod and it broke) and warped brake rotors, something everything I have had in the last 20 years has had. I like it better than anything I have owned preciously! I've been driving 32 years now and had over a dozen vehicles and I love it.
If you want a soft ride, get the Ford. It's not the equal, power wise of the Nissan, Dodge, or IMO, the GM trucks , but it's got a great interior, and is spooky quiet. Using that bed is not going to be easy, unless you are seven feet tall. My neighbor's F150 blew the tranny TWICE right after he bought it, and Ford replaced his truck. This one seems to be good.
Power wise, it comes down to the Nissan and the Ram. The Nissan is slightly faster than the Ram, and has, without question, the best performing transmission of all 1/2 tons. It's set up almost perfectly, drivetrain wise and uses lower numbered gearing the other trucks can't pull due to their more primative trans gearing. Bad points on the Nissan are they squeak and rattle in a year or two like the Chevey and Dodge do at 8-10. A guy at work had one of the first ones and going over a bad railroad crossing it sounds like it's coming apart.
The GM trucks, (I would look at GMC's myself, that Chevy front end is nasty) look good, and get the best mileage, about the same as the Toyota. The ride is good, they are fairly quiet and the 5.3 is a decent running motor. If you read about them, there will be mentions of CSK (Cold Start Knock). Some of them do it very badly, at least they did a couple of years ago. GM claims this is "carbon" on the tops of the pistons. BS, some engines were badly machined. My truck did it for about 5 seconds in the summer and 15 seconds in the winter, when started up after over a few hours sitting. My friend's nearly identical truck was much worse. It had a tiny water leak and the dealer decided to "decarbon" the heads and pistons when they replaced the head gaskets. Trouble was, there really wasn't any carbon, and when they started it up after "decarboning" it, it tapped away, just like it always did. Eventually, they replaced the engine. Mine stopped when I went to a different than stock oil filter.
The Toyota is a little smaller, a little less powerful, and a little slower. It's a nice truck in a lot of ways, but not for me. I don't like the looks of it either, too last generation F150 for me.
The Ram is the best looking (I liked the 94-2001 much better though) one, IMO, but the Ford looks good too. The GMs are ok, except for the awful Chevy front end, and are about to be replaced by new models. The Titan is pretty ugly though, and the Toy is ..blah. The Ram is pretty quiet, runs a close second to the Nissan (Just needs a better trans and it would move to #1), and is a lot of fun. It handles well for a truck and can be picked up pretty cheaply right now with the deals they have. An 05 identically equipped as my 03 can be bought for about 25K, or 2K LESS than I paid, and I got a really good deal for mine. A friend of mine just bought a 2500 Cummins 4x4 for like 32K. Sticker is about 42k!
Have fun shopping.
