- Nov 13, 2003
- 159
- 0
- 0
I am having trouble with my PC I ordered it from newegg and built it myself with previous experience of working as a tech. So far everything has been great I have just been running the pc at OEM speeds .. No over clocking yet at all... the cpu temp is 15c idle. I did the burn-in test with the free Sissoft Sandra and got no errors at all. I have installed Win XP Pro Corp Ed. I do notice the Ram only shows as 3gig under xp and heard that is normal.
My problem is when I start games I can play them for about 15 minutes or so ... Sometimes 30min to an hour. Then they close on me as if I had just terminated the process of the game. Leaving no error and returning me to my desktop just the way it was before I started the game.
My parts are listed below... I have no idea what the problem could be and no idea where to start looking. Could it possibly be that I need to install XP 64bit? Instead of just regular XP Pro??? Maybe because of the ram not being supported in the 32bit XP? I don't have a copy of the 64bit but I would go get one if you all think this may be the problem.
Other then that all mt parts are brand new out of the package. Its going to be hard to figure out whats wrong by replacing parts because they cost so much and all I would be able to do is guess work and start sending stuff back to newegg without knowing whats truly wrong or faulty.
Ok, thanks for helping guys if any of you have any ideas for me.
PC Power & Cooling Silencer 750 Quad - Copper EPS12V 750W Continuous @ 40°C (825W Peak) Power Supply - Retail
Thermalright Ultra-120 Extreme CPU Cooler - Retail
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - Retail
Creative 70SB046A00003 7.1 Channels PCI Interface Sound Blaster X-Fi Platinum Fatal1ty Champion Series Sound Card - Retail
Scythe S-FLEX SFF21E 120mm Case Fan - Retail
Western Digital Raptor X WD1500AHFD 150GB 10,000 RPM Serial ATA150 Hard Drive - OEM
EVGA 768-P2-N881-AR GeForce 8800Ultra 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported HDCP Video Card - Retail
ASUS Striker Extreme LGA 775 NVIDIA nForce 680i SLI ATX The Ultimate Gaming Motherboard - Retail
Thermaltake Armor Series VA8003BWS Black Full Tower Case w/ 25CM Fan - Retail
LG 18X DVD±R DVD Burner with 12X DVD-RAM Write Black E-IDE/ATAPI Model GSA-H54NK - OEM
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model BL2KIT12864AA1065 - Retail
^=4GB
^=4GB
