- Sep 21, 2005
- 80
- 0
- 61
I've recently built a new rig, and I'm having severe FPS drops on my main monitor while I pull up anything on a browser on my second monitor.
Both of my monitors are DVI only (overclockable version with single input) Both are running at 96hz via dual link DVI. The MSI 980 Ti only has one, so I specifically bought a second video card just for my second monitor. Main monitor into the 980 Ti, my second into the GT 610.
I've wiped the drivers clean, reinstalled everything clean in safe mode, disabled Aero, enabled multi GPU/maximum performance settings in control panel etc. Still having an issue.
Right before the 980 Ti, I had a 970 with 2 Dual Link DVI ports, and obviously didn't have any issues. I thought I'd be able to run two different video cards without an issue, but I think that's the culprit and don't know what to do.
Specs:
PCPartPicker part list: http://pcpartpicker.com/p/3KJQsY
Price breakdown by merchant: http://pcpartpicker.com/p/3KJQsY/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($318.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($27.99 @ NCIX US)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard ($146.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($99.99 @ Newegg)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Drive ($127.21 @ Amazon)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($161.99 @ Amazon)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive ($70.89 @ OutletPC)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card ($679.95 @ Amazon)
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case ($118.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA 1000 P2 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply ($177.99 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($18.89 @ OutletPC)
Operating System: Microsoft Windows 7 Ultimate SP1 OEM (64-bit)
Monitor: QNIX QX2710 Matte 60Hz 27.0" Monitor
I wanted to avoid having to use one of those expensive active DP to DVI adapters, and I didn't want to use the Gigabyte G1 980 Ti because the so called coil whine would drive me nuts.
Thoughts?
Specs:
Thoughts?
