[Troubleshooting] Need Help ASAP! New external build not displaying info on monitor!
Ursidae
I don't mean to spam. I just wanted to repost a thread because my last one did not get as much traction (which I strongly believe is due to me posting it really late) and I'm really desperate for help. I'm seriously distraught by this problem. I planned this build for nearly two years saving and researching. I have a disillusioned feeling since I did not mentally prepare myself for the worst. I only thought of a good outcome.
For my first build I decided to do an external build instead of throwing everything in the case (Thank God). The problem I'm having with it is that there is no information displaying on my monitor. Strangely enough, my hardware is running. I know this because the fans on my PSU, CPU cooler, and GPU fan and LED are running. No hissing or turbulent sounds, only a nice smooth humming sound.
If you are interested in helping me then refer to the MSI Motherboard Manual. Third download from the bottom that is 7.29 MB is the manual.
Pictures of setup:
https://imgur.com/a/wxDbJ
What is happening:
External build is not displaying any BIOS or information even when hardware is running fine.
What I've tried so far:
  • Took out both RAM chips
    Took out one RAM chip
    Moved one RAM chip to another DIMM slot
    Moved both RAM from DIMM1 and DIMM 2 to DIMM 3 and DIMM4
    Took out dGPU to run from iGPU
    Reset the CMOS for 25 minutes
    Used VGA cable from motherboard to monitor (I did not connect the VGA to the GPU because it does't have one. It only has 1xHDMI, 2xDVI, and 3xDisplayPort.
    Used HDMI from motherboard to monitor
    Used HDMI from motherboard to GPU
    Did not use DVI or DisplayPort because my GPU did not come with one.
What I think might be faulty:
  • CPU—Not sure if the method of which I installed the CPU cooler might have potentially damaged it.
    Motherboard— I did not take the time to check the pins if they were damaged. The motherboard is also not illuminating my K70. I plugged it into my newly purchased laptop and it illumined without having to install drivers so I assume an area near the I/O ports have been damaged.
    CPU Cooler—I might have installed the standoffs too tightly.
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($33.03 @ Amazon)
Thermal Compound: Noctua NT-H1 3.5g Thermal Paste ($5.56 @ OutletPC)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard ($137.99 @ Amazon)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory ($76.17 @ NCIX US)
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($112.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card ($368.99 @ NCIX US)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case ($119.99 @ NCIX US)
Power Supply: Rosewill Hive 650W 80+ Bronze Certified Semi-Modular ATX Power Supply ($74.73 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($14.99)
Monitor: Acer H236HLbid 60Hz 23.0" Monitor ($179.98 @ OutletPC)
Case Fan: NZXT FN-140RB 62.5 CFM 140mm Fan ($9.99 @ Amazon)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard ($129.99 @ Amazon)
Other: Perixx MX-1800B ($21.99)
Other: Blue Microphones Snowball USB Microphone (Gloss Black) ($49.99)
Other: Phanteks PWM Fan Hub Controller ($14.99)
Total: $1646.34
Would you link us to your other thread so that we can see what has been covered?
One potential issue I see is that your Haswell refresh CPU requires a BIOS that is one version newer than the one the board likely came with.
The interesting part is this seems to only apply to the K chips. I would think that it would at least boot, but IIRC I have seen two people here who could not get theirs to boot at all on an older BIOS.
