I've just put together a new system, but my skills and knowledge in this department is quite limited, meaning that I barely managed that much (requiring the help of manuals and some googling) but lack the insight to efficiently troubleshoot my current issue. (Also I apologize in advance for any terminological mistakes etc).
I have a MSI Z270 SLI PLUS, an i5 7600K, and Corsair Vengeance LPX 3200 mhz 2x8 gb powered by a Corsair RM550X psu.
The system works fine and appears stable so far but with an important caveat. The memory runs at the default 2133 speed, and if I try to activate XMP (or manually set it to 3200 with everything else auto) the system fails to boot and after a restart gets me back into BIOS where I can turn off XMP. The same thing happens if I activate OC Genie but without doing anything else. I had some time yesterday after work to experiment with raising the speed step by step yesterday and at 2666 (again everything else auto since I don't know that much) everything seems stable although I haven't run memtest86 to check for errors (I though I'd try pushing it further tonight).
MSI support suggest to remove the CPU and check the cpu pins to see if there's any damage. I'd rather not though since that would present another opportunity for me to mess things up (which is what happened to my old system in moving it from one case to another), and to me it sounds counterintuitive that there would be something wrong with the CPU if the system runs fine on default speeds (although admittedly intuition can be quite unreliable when you possess very limited knowledge).
So to my question - is it possible to say what the odds are that the CPU (or some other part) is damaged and needs to be RMA:d? If it is damaged, is the only consequence not being able to run things at full/OC speeds or can there be more malfuncitons down the line even at default sppeds? I'm trying to decide whether I can stick my head in the sand and at worst have to live with the memory running on less than full speed (if it doesn't get fixed in a bios update) or whether I should try to find out now whether there is anything damaged so that I can return it while I still can.
(MSI says that they've tried the exact memory I have at 3200 with the motherboard and that it should be working but Corsair doesn't seem to list any MSI Z270 boards as compatible with the memory. I've made sure to use the rights slots according to the MSI manual).
Is there any less "invasive" troubleshooting steps to take before removing the CPU?
Thanks
Niles
Thanks
Niles
