- Feb 26, 2005
- 23
- 0
- 0
Greetings,
I recently changed out a motherboard on an old computer. I upgraded to a gigabyte EP45-UD3P, and I threw in a C2D E5200 to run the system. I kept my old hard drive, and I assumed that by just plugging in the old hard drive into the new motherboard, everything would boot up as normal, just a bit faster.
When my computer starts, the windows screen comes up and states that windows was shut down improperly and asks if I want to start in Safe mode/normal mode/ETC..... I try the different modes, and I still can't get the computer to start. It loads the bios startup screen, then proceeds to the safemode window. I'll get my windows disks later and try to repair windows, I was just hoping somebody had a quick answer as to what was going wrong?? The only connection I changed on my hard drive, is instead of connecting it with the 4 pin power cable, I connected it with the newer flat power connector found on the newer power supplies (I upgraded the power supply as well).
Any Ideas why windows won't start?? I know the reasons are probably too many to list, I was just hoping maybe there was a quick list of todo's I should double check, or if I need to repair windows with the windows disks??
Any help would be much appreciated.
Thanks,
Thanks,
