I had setup an internet sharing before that was cabled and had no problem at all. The lady had Verizon, Fujitsu modem and Linksys router with two ethernet cards and some cables. It worked fine and went smoothly.
Today, some one else wanted the same thing but only wireless. So she has Verizon, Fujitsu modem, wireless Belkin rounter, and USB Belkin wireless ethercard. The main computer is cables to the wireless router and the modem.
1) I got the DSL running with the modem and the wireless router and it worked perfectly.
2) Now on to the 2nd computer with the USB wireless network adapter. I cannot get this one to see the router or connect to the internet at all. I tried for 3 hours and gave up and said to come back tomorrow.
I need to do some research and need your help. Here are some of the settings:
The channel is 11.
The SSID is ANY or WLAN
Infrastructure or 802.11b, I have tried both and none of them work. Which one should I select?
I cannot get the computers to network at all. The main thing to get the DSL shared.
Any hints or help is most greatful.
Thanks.
The channel is 11.
Thanks.
